  3. How to assign net name to mechanical PAD?
  • Views 16028
newstyle
newstyle over 12 years ago
For example, i should seperate the Die pad of Die bonding package components.
I found the net files are based on the whole device, if I seperated them, I try to assign the net name on each PIN, but i got the message:  only component PINS can be assigned.
 Then how to assign net name to those seperated pins?  Supposed I can't update the schematic.
LJ
  • msm2012
    msm2012 over 12 years ago
    Hi
    I have the same question here How to asign a net name to a mechanical PAD ?
    Can anyone give a indications ?
    Thanks and Regards
    Mehdi
  • newstyle
    I solved it , just delete the net name ,delete txt
  • msm2012
    Sorry i did not get it.
    I placed mechanical pads on the board and I wanted to assign a net name to it.
    How to do that ?
  • newstyle
    oh, i see. my reply is from Net pin to be mechanical pin.
     Then, you need add part netlist, add a new part in this list, then you creat net name and assign.
    net name can only be assigned on component pins, so firstly make this mechanical part is a component.
