  3. Step package mapping
  • Subscribers 163
  • Views 15114
padmaster
padmaster over 13 years ago
First time playing around with this functionality. I downloaded a step file of a SMT DIP switch, mapped the step file to the package and it appears to be working correctly but when I go to the 3D view, I still see just a nondescript block for that switch. Is the step model function working properly or is it still "under developement"?
Win XP, 16.6 with latest hotfix #13.
  • fxffxf
    fxffxf over 13 years ago
     For now set the env variable, in your local env file
        set step_unsupported_prototype
    then restart allegro. Starting with ISR 14 you won't have to do this workaround
  • padmaster
    that worked, thank you very much
