  3. how can i set the drawing order in pcb designer 16.5
  • Views 12542
Usane
Usane over 12 years ago
Hi!
First, sorry for my bad english.
I am relatively new in orcad pcb designer, layout was a little easier. i made two pcb for the same project. It is a one piece project for testing, and i want to plot the layers for personal manufacturing, and i want to print the pads with the holes. I set up the drill color to white and etch color to black and printed in color to pdf. Worked fine, the pads was printed as rings. It was visible on top layer but on bottom layer the connect lines covered the holes. After this i replaced the padstacks to a little bigger, and the visibility has changed. The holes was visible on bottom layer and was covered by connect lines on top layer. So something happened with "drawing order", and i dont know how to change it back. My question is that, how can i manipulate the "drawing order" without ripup the existing etch. Is there an easy way?
  • oldmouldy
    oldmouldy over 12 years ago
    Go to the Capture Marketplace from within Capture / Start Page, then OrCAD Apps, list all the apps and there is a "Prototype Plotting with Open Drill Holes" App, free download, which will get you what you need for Prototypes.
