  3. function key
  • Subscribers 166
  • Views 14791
function key
D912349
D912349 over 12 years ago
Is there a way to combine following commands in a single key using maybe alias or funckey?
commands to combine:
shape add,  right click, assign net..
  • ScottCad
    ScottCad over 12 years ago
    Hello, Yes there is.
    Here is a small macro to do what you need to do.
    funckey s "shape add; setwindow form.mini;FORM mini dyns_netname_list"
    I assigned it to the s key on my keyboard :)
    when you add the macro to your env file and hit the assigned key in Allegro it will pop up a dialog box so you can select the net for your shape. Keep in mind function keys in allegro are case sensitive. Works pretty good.
    Thanks Scott.
  • D912349
     Hi Scott,
     I tried it and it works fine. but then, is their a way to not select a net on a list?. what I want is to select a pin/rat/shape or any valid object and it will get the net assigned to that object then assign it to the shape that will be create.
  • ScottCad
    Yep you can do it that way too. That's kind of similar to the default action.
    Try this instead.
    funckey S "shape add; pop net list"
    run the hotkey, click  your object that has a net and draw the shape you need.
    Thanks Scott
  • SSSMANI
    SSSMANI over 7 years ago in reply to ScottCad
    It Showed E- Unmatched quote
