  3. NETREV ERROR WHILE IMPORTING
  • Subscribers 163
  • Views 17406
girish
girish over 12 years ago
Hi all,
I was getting strange error while importing , error log shown below .
No issue in  schematic netlisting , while importing its throwing below error & board file save as #Taaaaao05016.SAV
If I edit the extension change to .brd it will open , pls let me anybody faced same issue ?
(    Allegro Netrev Import Logic                                      )
(    Drawing          : IW-PREDZ-BF-01-R1_0_050913_1931.brd           )
(    Software Version : 16.6S015                                      )
(    Date/Time        : Thu Sep 05 19:34:05 2013                      )
------ Directives ------
RIPUP_ETCH FALSE;
RIPUP_DELETE_FIRST_SEGMENT FALSE;
RIPUP_RETAIN_BONDWIRE FALSE;
RIPUP_SYMBOLS ALWAYS;
Missing symbol has error FALSE;
SCHEMATIC_DIRECTORY 'D:\CADD_WORK\PREDZ\SCH';
BOARD_DIRECTORY '';
OLD_BOARD_NAME 'D:/Cadd_Work/PREDZ/BOARD/IW-PREDZ-BF-01-R1_0_050913_1931.brd';
NEW_BOARD_NAME 'D:/Cadd_Work/PREDZ/BOARD/IW-PREDZ-BF-01-R1_0_050913_1931.brd';
CmdLine: netrev -$ -i D:\CADD_WORK\PREDZ\SCH -y 1 -z -v D:/Cadd_Work/PREDZ/BOARD/#Taaaaao05016.tmp
------ Preparing to read pst files ------
#1   ERROR(24) File not found
     Packager files not found
#2   ERROR(102) Run stopped because errors were detected
netrev run on Sep 5 19:34:05 2013
   COMPILE 'logic'
   CHECK_PIN_NAMES OFF
   CROSS_REFERENCE OFF
   FEEDBACK OFF
   INCREMENTAL OFF
   INTERFACE_TYPE PHYSICAL
   MAX_ERRORS 500
   MERGE_MINIMUM 5
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
   NET_NAME_LENGTH 24
   OVERSIGHTS ON
   REPLACE_CHECK OFF
   SINGLE_NODE_NETS ON
   SPLIT_MINIMUM 0
   SUPPRESS   20
   WARNINGS ON
  2 errors detected
 No oversight detected
 No warning detected
cpu time      0:01:00
elapsed time  0:00:00
Best Regards.
Girish Kumar
  • chads108
    chads108 over 12 years ago
     I guess the obvious question is, are you sure you are pointing to the folder where the packager files are on the Import directory line?  Just looking at the error would suggest you are not.
