  3. Replace Thru Hole via with BB via
  • Views 13107
FrancisFogarty
FrancisFogarty over 12 years ago
Hi Guys,
im just wondering how i can change a thru hole via to a BB via? and if possible all instances of a particular TH via to BB via.
Regards
Fran
  • steve
    steve over 12 years ago
    In General edit mode either select the via (s) you want (try rmb - selection set - select by polygon, lasso or path) when they highlight hover over any on of them and use rmb - replace padstack - selected instances and then browse for the bbvia (database selected). THis will change any via regardless of the connection it makes so be warned....
  • FrancisFogarty
    Thanks for this, i remember now. cheers
