  3. Auto Routing issue
  • Views 13713
Auto Routing issue
EverLasting
EverLasting over 12 years ago
 Hi everybody
I'm a beginner in orcad pcb desighn,and i have created a circuit using  orcad capture V16.5 sw then trnasfer it to pcb editor and when i have made autorouter,
i found that some tracks are crossed, and they shouldn't be and i don't know why it's crossed,
is it an issue in autorouting?
or i'm doing some thing wrong
or there any configurations befor using auto routing
so pls help
  • redwire
    redwire over 12 years ago
     There are some circumstances when the autorouter is stopped before the proper clean-up passes are run where you will see intersections.
    Can you please give a detailed list of how you started the autorouter from your design?
  • Robert Finley
    Robert Finley over 12 years ago
     Ok, its been a few years since I had the opportunity to use this.
     But, "clean" and "critic" are two commands you may want to run after the route.  Clean works differently than the normal route routine and multiple passes can be run.
    Critic removes all DRC proximity and net short errors before you bring the layout back to Orcad in a single pass.
  • EverLasting
     hi
    here what i have done
    I have created a netlist from capture to transfer the desighn to pcb editor and after adding the components to the created board i've pressed autorouting icon then in the appeared window i selected the bottom layer and pressed route .
  • EverLasting
     hi Robert Finley
    could you please tell me how to use these commands
