  3. offset solder mask from net/trace/cline
  • Replies 12
  • Views 8257
FrancisFogarty
FrancisFogarty over 12 years ago
Hi Guys,
im just wondering is it possible to assign a soldermask area to be offset from a net or put another way is it possible to assign to a net/trace a soldermask.
see i have curved lines and i need a soldermask area to prevent soldermask been put onto the trace/clines. see attached images of my board.
All help very welcome.Thanks
 Regards
Fran
  • steve
    steve over 12 years ago
    Theres a free app available from the OrCAD Capture Marketplace called Graseware ClineRouteKeepout that will create a route keepout area based on the clines. Once that's been used you can zcopy the shapes to the soldermask layer. Go to:-
    orcadmarketplace.com/ProductDetails/tabid/93/ProductID/40/Default.aspx
  • FrancisFogarty
    Hi Steve,
    thanks for the reply can this software be used with Allegro PCB designer?
    Regards
    Fran
  • FrancisFogarty
    Sorry just seen that it can be. cheers thanks for the help.
  • FrancisFogarty
    Hi Steve,
    i have tried the using the tool Graseware  ClineRouteKeepout its a handy tool. but when  i zcopy the route keepout shape to the soldermask top layer it doesnt create soldermask over the actual traces themselves only over the clearance. Any ideas?
    Regards
    Fran
  • steve
    The tool makes a route keepout that is larger than the track by the amount you specify. When you zcopy that shape to a soldermask layer use the contract option in the Options window to make the shape the same size as the track again.
