  3. Problem with footprints ACS756
  • Subscribers 163
  • Views 14066
legnar
legnar over 12 years ago
I am using ORCAD Layout Plus Package 16.0 Windows XP to create footprints some components. I'm having trouble creating the footprints of the two larger holes ACS756component because the layer only accepts drill pad round shape. Here below a picture of the component specifications. I ask for help from someone who can give me some tips or if there is any example that I can send.
 [IMG]imageshack.us/.../IMG]
  • oldmouldy
    oldmouldy over 12 years ago
    OrCAD Layout has no inbuilt support for slot component holes, you would need to discuss with a PCB fabricator how to document you requirements so that the required structure gets manufactured. You can set the drill for the minor dimension, describing the slot requirements would likely be specific to the actual fabricator used. PCB Editor does have inbuilt support for slots as padstacks.
  • oldmouldy
