  3. Allegro PCB SI - via model errors
  • Subscribers 163
  • Views 1899
Wild
Wild over 12 years ago
Topology extraction - probe.  Simulation fails vias due to via model errors.
Tried the board simulation in 16.3, 16.5, 16.6 errors in all attempts.  Rexacted the via models from the board file, failure.
Moved to  a different box to run the simulations, there were no errors.
Differences between systems - Windows 7 vs. Windows XP.  Simulations run on windows XP box.
Question:  Is there a known issue or work arround for PCB SI with windows 7?
Note: Latest hotfix (10/23/2013) on all versions.
  • Sumit Sharma
    Sumit Sharma over 12 years ago
    are you able to extract the topology for the address bus of DDR?
  • Wild
     The board that I am simulating is a telepony based platform that we designed it has no DDR, but sevral IBIS models with PCM SPI and I2C interfaces.
  • Wild
    Allegro 16.6
    Resolved the topology extraction isssue.
    Turned down the UAC in windows 7.
    This also resolved the issue I was having with imbedding OLE  objects into Capture.
  • Wild
    Update fromcustomer support:
    Deleted the temp and tmp paths in the user variables.
    Lowering the UAC only solved the OLE  immbedding in Capture (ORCAD)
