  3. Changing DRC ( Spacing Constraint) rules in allegro.
  • Subscribers 163
  • Views 18379
RFStuff
RFStuff over 12 years ago
 Dear All,
I am using Allegro 16.2 tool for my PCB layout.
Earlier I designed my PCB layout in Board not in Board Wizard.
My DRC check is showing error when the trace spacing is lesser than 5mil.
But now, I want to change this DRC rule ( Spacing Constraint) i.e. the  Minimum Line to Line spacing to 10 mil.
How I can do this .
Also I need to change the constraint for Shape to Shape spacing.
Could anybody please tell how it can be done .
Kind Regards
  • redwire
    redwire over 12 years ago
     All constraints are managed through the constrait editor.  There is normally an icon to get you there but otherwise it's Setup->Constraints->Spacing
    Dig into the other constraint menus as well.  Constraint editor is a little cumbersome at first but then makes sense.  It's used for spacing, electrical, matching, and relational constraints.
