  3. Gerber & Drill Viewer - What's out there?
  • Subscribers 167
  • Views 2565
UlfK
UlfK over 11 years ago
All,
I have for many years been using Viewmate (Pentalogix) although never having been able to view the drill files together with the gerber data. But - my designs has worked and boards delivered has been fine. A collegue of mine has been using Camtastic..."something" in order to review my data and he was also unsuccessful in trying to look at the drill data.
Nothing strange. I use metric data, RS274X, excellon, leading zeroes omission...
So my question is: Does it exist a free viewer that can import and display the drill data together with the gerber layers?
  • RTMORA2
    RTMORA2 over 11 years ago
    Ulfk,
    I too use Viewmate. To view the drills along with the gerber, I create a directory containing only the gerbers and drill files.
    In viewmate select import/directory. The gerber and drills are now in your viewmate viewer.
    I have noticed that Viewmate seperates the drills into their own layer, but they're in there.
    Ron
  • UlfK
    Been there. Done That. My problem is that the drill data will not display in the same scale as the gerber data. I use Metric output, with same accuracy x,y for both Gerber 274X and Drill but ViewMate rescales the drill data to something which I am not able to adjust.
  • ScottCad
    ScottCad over 11 years ago
    Hello, a popular Free version viewer is available from
    http://www.graphicode.com/GC-Prevue
    Called GC-Prevue. This has been around for a hell of a long time and should do what you need.
    Thanks Scott
