  3. Couple of PCB Editor Questions
  • Subscribers 163
  • Views 13821
PurdueMark
PurdueMark over 12 years ago
 I've searched numerous places and can't seem to find the answer to these two questions regarding symbol modification in Editor.
1)  Load a .dra file into Editor,  its a previously built symbol that I simply want to change the position of an outline on the Assembly_Top layer.  I seem to be only able to pick up the entire outline instead of stretching or moving a single end point,  .   Is there a way to move a line similar to the way rectangles are modified?
2) Is there a way to manually re-number pins?
 MSC   10/31/13
  • chads108
    chads108 over 12 years ago
     1.  Edit => Vertexlets you move endpoints or anything in between.  You can also change the find filter by turning off Lines and turning on Other Segments
    2. Changing pin numbers is as simple as editing the pin number text.
