  3. Error During Export of ODB++Inside
  • Subscribers 163
  • Views 6688
ScreenName360
ScreenName360 over 12 years ago
Hello All,
When trying to export the ODB++ with C:\Valor\ODB++Inside, I get the error:
Windows platform
*********** ERROR  18Nov2013.164607.861  6244  8.1(55) Windows Vista
Cadence Interface - File layers_326288ck1_01a.out has wrong header
Status raised : module - G:\s81\eif\eif_cadence.c, line - 3155
Status raised : module - G:\s81\eif\eif_cadence.c, line - 2889
Status raised : module - G:\s81\eif\eif_cadence.c, line - 2608
*********** ERROR INTERNAL 18Nov2013.164607.861  6244  8.1(55) Windows Vista
(ind_list != NULL && ind_list->magic == IND_LIST_MAGIC) at G:\s81\gen\gen_sort.c 1236
Status raised : module - G:\s81\eif\eif_cadence.c, line - 2169
Status raised : module - G:\s81\eif\eif_main.c, line - 490
Status raised : module - G:\s81\translators\brd2odb\brd2odb.c, line - 462
Failed to translate job !!!
Status raised : module - G:\s81\translators\brd2odb\brd2odb.c, line - 1820
*********** WARNING  18Nov2013.164607.862  6244  8.1(55) Windows Vista
T r a n s l a t i o n   e n d e d    W i t h   E r r o r s
However, when i tried using C:\MentorGraphics\AllegroExportODB++, the ODB++ generation works. The version of the Valor ODB++ Inside is 08.01, Build 55. The system environment variable for ALLEGRO_BRD2ODB= C:\Valor\ODB++Inside
Any ideas or thoughts? Thanks!
  • mcatramb91
    mcatramb91 over 12 years ago
    In the cases where I ran into an issue with ODB++ generation, I would always go to Mentor Graphics ODB++ Inside web page and download the latest translator. Here is the link that is presented when attempting to run File > Export > ODB++ Inside, which you would see if the ALLEGRO_BRD2ODB was not set ->   http://www.mentor.com/pcb/downloads/odb-inside-trader
    Also on this web page there is an email address / phone number for support and questions (as oldmouldy indicated)
    By the message, it looks like the SKILL routine (VALOR_EXT.IL) that is being used to generate the post process files for ODB++ generation does not match the version of ODB++ Inside you are running.  You should always use the VALOR_EXT.IL file located in the ODB++ Inside folder of the translator you are using to avoid any conflicts.  The VALOR_EXT.IL in the ALLEGRO_BRD2ODB Folder is loaded/used by default unless you have another version of the SKILL file loaded using $HOME/PCBENV/ALLEGRO.ILINIT
    All else fails you can contact ODB++ Inside support using the email/phone on the ODB++ Inside web page.
    Good Luck,
    Mike Catrambone
  • mcatramb91
    Good Luck,
    Mike Catrambone
