  3. Layout to ODB++ Export
  • Views 23337
DomTech809
DomTech809 over 12 years ago
I’m trying to export PCB build data from Orcad Layout 16.2 but the exported ODB++ files are not complete according to the board house.The help file in Orcad Layout points to a link do download the translator but it seems to be broken. Is there any other way to download the translator?
I’ve tried the steps provided in the below forum, seems that other people have had the same problem.
http://www.edaboard.com/thread70848.html
I will appreciate any help with this.
  • fxffxf
    fxffxf over 12 years ago
     Valor has changed the location to:
         http://www.mentor.com/pcb/downloads/odb-inside-trader
     Since Orcad 16.2 out of support this link update is only reflected in supported OrCad software such as 16.5 or 16.6.
  • DomTech809
    I installed the ODB++ Inside from the provided link, but when I do a File->Export->Layout to ODB++ within OrCad Layout I get an error that says "Unable to find the GW2ODB.exe executable file.
    Any ideas?
  • oldmouldy
    oldmouldy over 12 years ago
    You have the current BRD2ODB interface, this takes a PCB Editor BRD file as input. You need the obsolete "gateway" interface, GW2ODB, since OrCAD Layout used the "gateway" method to generate the ODB++ output. You might be able to find some download links to get the GW2ODB executable but, since neither OrCAD Layout, not the Valor "gateway", are supported any longer, you may not be able to find what you need and get it working.
  • DomTech809
    I've been searching online for the GW2ODB and have not been lucky. I have many "legacy" boards that I need to create the ODB++ files for and it will be time consuming to convert them all to PCB Editor. It seems a little ridiculus that even if the software is not supported the GW2ODB should at least be available for download, easily. Someone out there might have it and Valor has not been helpful at all.
  • pcbapc
    pcbapc over 12 years ago
     You have to select the type of require material from low temp to high temp  FR4 to FR408 , GTEK , POLYAMIDE , ROGERS , Metal Core (Aluminum),Rigid Cem-1 to Cem-3 , are the most common types.You can go this links
    http://www.pcbapc.com/pcb_manufacturing_and_designing.php
    it might be helpful for you.
