  3. is it possible to highlight the dummy pins ??
  • Replies 10
  • Subscribers 166
  • Views 18746
kabalee
kabalee over 12 years ago
Hi everyone,
is it possible to high light the dummy pins for perticular components ??
is it possible to explain the Topology ?? (Daisy chain ,T-point ,star topolpogy )
where it will be use  ??
  • padmaster
    padmaster over 12 years ago
     To highlight all dummy net pins....
    Select Assign Color
    Select the color you want
    Select Solid or Pattern
    In the Find filter select Nets
    Under Find by Name, Select Net
    Then type in "dummy" as the net name to the left of the "more" button
    Not sure what version you are running but I have been using this method since at least 16.2
  • padmaster
    Select Assign Color
