  3. Model Editor - Can't "Extract model"
  • Subscribers 163
  • Views 4392
Javier1234
Javier1234 over 12 years ago
Hello all!
I have opened with Pspice Model Editor Demo a .lib library of an IGBT  that I downloaded from a manufacturer and the option "View-> Extract Model" is not enabled. Is it because the model is somehow “protected” by the manufacturer or is it because I’m using the “Demo” version?? I couldn’t find any explicit mention to it in the “OrCAD Lite Products Reference”
And while I’m at it, if I understand it correctly, a .lib file contains the same instructions as a netlist file. Then my question is: Is it possible to display a schematic out of a .lib file? It would help me a lot to visually see the model I’m using, instead of reading the .lib file…
  • oldmouldy
    oldmouldy over 12 years ago
    "Model Editor / View>Extract Model" is only available if you have defined the model from parametric curves taken from a datasheet (for example) and entered into a new model. The "Lite" version only supports defining modles in this way for Diodes.
    IF you have a LIB file / model from a manufacturer, that file already contains the extracted model parameters, and / or subcircuit, to define the model to the simulator. You just need to save the LIB file from the Model Editor and map the model to a schematic part, if you are going to use Capture, or ADA,  as the input to PSpice, File>Export to [..] library, or File>Model Import Wizard will take care of making the symbol. See the PSpice Users Guide, pspug.pdf in the doc\pspug directory, Appendix C for importing SPICE models for use with PSpice.
  • Javier1234
    thanks oldmouldy!
    regarding my second question, if I understand correctly, what I can read in an .olb file are SPICE instructions like in a netlist. Is it possible to generate automatically a schematic out of this text file?
  • oldmouldy
    The OLB file is the graphical, schematic part, library for Capture, this is used to draw the schematic for extration to a PSpice netlist. The LIB, text, file could be a sub-circuit of SPICE elements but to get this to a graphical representation would not be trivial. If necessary, it's usually best to attempt this with a blank sheet of paper and draw the elements and interconnections, then tranfer a revised version to a schematic - this is not really going to impact the simulation itselft, only explain the circuit elements of the subcircuit.
  • Javier1234
    yes, that's what I've been doing so far, but I wanted to check if the schematic that I draw by hand was correct.Thanks oldmouldy and Merry Christmas!
