  3. [Help] PADS layout to Allegro PCB translation
  • Views 21520
momo1982
momo1982 over 12 years ago
Hi all,
First, thanks for the time of you on this post.
I have a 8-layer PADS PCB layout designed by other people, which you can see from the attached Figure 1. What I want to do now is to extract the footprints of components in the PADS board layout to Allegro, so I don't need to redraw the footprint of some component. I have done some homework on the procedure, which is explained below, but still can't get it done.
The version of the PADS software is 9.5. The Allegro version is 16.6.
1: First, export the PADS PCB layout into .sci format. The settings is in attached Figure 2. Is it correct?
2: Copy the default pads_in.ini file to my directory. The contents of this file is listed in Figure 3. But I don't know how to modify it based on my case.
3: Launch in Allegro that File-->Import-->CAD Translator-->PADS, choose the .asc and .ini file, and run Translate.
I get some errors here, which is listed below:
Using translator version @(#)$CDS: pads_in.exe v16-6-112X 3/11/2013 Copyr 2013 CADENCE DESIGN SYSTEMS.
Reading PADS ASCII file header.
PARSE ERROR: Unrecognized format in header line of input file.
Line 1: !PADS-POWERPCB-V9.5-BASIC! DESIGN DATABASE ASCII FILE 1.0
ERROR: Finished with errors.
  • momo1982
     Figure 2.
  • momo1982
     Figure 3.
  • momo1982
     I also include here the beginning part of .asc file.
    *PARTDECAL* ITEMS
    *REMARK* NAME UNITS ORIX ORIY PIECES TERMINALS STACKS TEXT LABELS
    *REMARK* PIECETYPE CORNERS WIDTHHGHT LINESTYLE LEVEL [RESTRICTIONS]
    *REMARK* PIECETYPE CORNERS WIDTH LINESTYLE LEVEL [PINNUM]
    *REMARK* XLOC YLOC BEGINANGLE DELTAANGLE
    *REMARK* XLOC YLOC ORI LEVEL HEIGHT WIDTH MIRRORED HJUST VJUST
    *REMARK* VISIBLE XLOC YLOC ORI LEVEL HEIGTH WIDTH MIRRORED HJUST VJUST RIGHTREADING
    *REMARK* FONTSTYLE FONTFACE
    *REMARK* T XLOC YLOC NMXLOC NMYLOC PINNUMBER
    *REMARK* PAD PIN STACKLINES
    *REMARK* LEVEL SIZE SHAPE IDIA [CORNERRADIUS] [DRILL [PLATED]]
    *REMARK* LEVEL SIZE SHAPE FINORI FINLENGTH FINOFFSET [CORNERRADIUS] [DRILL [PLATED]]
    0402 I 38100000 38100000 2 2 1 0 2
    OPEN 4 381000 0 0
    -476250 1143000
    -2209800 1143000
    -2209800 -1143000
    Anybody could give me some help?
    Thanks so much~~
  • momo1982
     Problem Solved by myself...
     Choose PADS Layout V2007 when exporting .asc file, no matter what your PADS version is. No need to modify .ini file.
  • Robert Finley
    Robert Finley over 12 years ago
    Only thing we noticed is the translated symbols left us without DFA or placement DRC boundaries.
    The translator makes no attempt to reuse existing padstacks.  Just builds new padstacks with a serial number each time.
    Used our library automation to generate a second library with footprint names matching what we had in PADS (we didn't follow IPC naming convention back then).
