  3. No Pspice Design Template for IRF150 in Orcad Lite 16.6...
  • Views 14833
No Pspice Design Template for IRF150 in Orcad Lite 16.6?
Javier1234
Javier1234 over 11 years ago
Hello all, I'm trying to simulate a circuit with an IRF150 (from the EVAL library) in Orcad Lite 16.6 and when I create the netlist I receive the warning "WARNING(ORNET-1119): No PSpiceTemplate for M1, ignoring", M1 being the IRF15. Does that means that the IRF150 is not supportedanymore in the LITE version? If I recall correctly with PSpice 9.2 it was included.
Many thanks in advance
Cheers!
  • Alok Tripathi
    Alok Tripathi over 11 years ago
    Yes. This is a problem and seems to be legacy issue. I have attached the corrected .olb file. Replace your existing <installdir>/tools/capture/library/pspice/eval.olb with this one.
    eval.zip
  • Alok Tripathi
    Yes. This is a problem and seems to be legacy issue. I have attached the corrected .olb file. Replace your existing <installed>/tools/capture/library/pspice/eval.olb with this one.
