  3. alias or funckey
  • Replies 7
  • Subscribers 166
  • Views 18520
alias or funckey
docb
docb over 11 years ago
I'd like to assign a key to toggle betwreen general/etch/placement with alias or funckey.
Is it possible to have a key toggle something like that?
  • Randy R
    Randy R over 11 years ago
    Here's an example of setting it to F5:
    alias F5 "settoggle CMD 'generaledit' 'placementedit' 'etchedit';$CMD"
  • KARPCB
    KARPCB over 11 years ago
     Thanks Randy.. Its working.
  • PRASH36
    PRASH36 over 11 years ago
     Is there is any way to toggle between layers????
    Eg: Top/Botton/Sig1/Sig2 etc....
    Regards
    Prashanth
  • docb
    Thank you!
  • Randy R
    @PRASH36,
    Probably.  Instead of providing an exact method, here's the general process for using an alias/function key that can be used for many different requirements:
    1) record a script that does what you want
    2) open the script file with a text editor to get the commands
    3) put the commands in your alias or function key assignment statement (using alias with settoggle is the example in this thread)
    4) see if it works
