  3. copy between designs?
  • Views 15373
docb
docb over 11 years ago
I have a line/frame I'd like to use around each board where I have versions numbers and notes listed. Right now I export as a DXF and then reimport to other design. It's painful.
Is there a better way to do what's basically just copy and paste?
  • stump1019
    stump1019 over 11 years ago
    Frame? Not sure what you are referring to as a frame? All depends on what class or subclass you want?
    If it's a drawing format you could import the .dxf file into a .dra and create it as a .fsm.
    You could always create a .bsm and load the dxf one time then put it in your library and you could place it as a mechanical part at the board level. If you have custom subclasses you could even do that at the .bsm level.
  • docb
    I basically just want to copy some elements from one BRD and paste them into another.  These aren't devices - it's just the text frame and assembly notes that I want to copy each time.
    In the schematic editor - since I can open two files - that's easy.
    In PCB editor, how do I do it?
  • redwire
    redwire over 11 years ago
     Lots of was to handle this.  Any one of the options below can be used...including previous recommendations
    1) Establish a common template and use it to start your boards.  Link new schematic to template and update
    2) Establish a symbol for the board outline and place it
    3a) File->Export->Sub-Drawing - (old board) (be sure to follow the cues in the command line box for each step)
    3b) File->Import->Sub-Drawing (new board)
