  3. Concept HDL Net list Importing error in VLCT RASP HIP cadence...
  • Views 15312
Concept HDL Net list Importing error in VLCT RASP HIP cadence 16.6 PCB
yuvarajvolt
yuvarajvolt over 12 years ago
     I have following error while importing netlist in VLCT RASP HIB SEED PCB. Anyone can help me to clear this error.
#1   WARNING(SPMHNI-192): Device/Symbol check warning detected. [help]
WARNING(SPMHNI-194): Symbol 'DIP1' for device '6453962_POGO' not found in PSMPATH or must be "dbdoctor"ed.
    Alternatively, the JEDEC_TYPE is not defined for the device in the pstchip.dat.
  • Johan J
    Johan J over 12 years ago
     As Steve says, you are missing the footprint DIP1 in the PSM path.
    But this is also a standard warning when there is no footprint defined, either in the chips.prt file or int the PTF files.
    So first I should see if the footprint are defined in the schematic library, before I created a new footprint.
    /Johan J
  • Johan J
    /Johan J
