  3. ODB++
  • Views 14254
ODB++
OLY29
OLY29 over 12 years ago
We are having problems with the ODB++ information not matching the placement information or the IPC-2581 output. We have some parts placed on the board at strange angles and the output from ODB++ is 360 degrees different than the placement file and the IPC-2581 information. I have heard that it could be an ODB++ problem which comes from Mentor so I am not sure how to address this. Anyone have any suggestions?
  • steve
    steve over 12 years ago
     Try contacting Mentor via the odb_inside@mentor.com. Also check to make sure you are using the latest release of the odb++ inside translator.
  • steve
