  3. Export PCB for easy viewing
  • Subscribers 166
  • Views 14881
isii
isii over 11 years ago
For Altium projects, I've been exporting all projects to PCAD format so that I can check al PCB layouts very easily using PCAD viewer. It's a a very simple and effective viewer for checking anytime the PCB layout. You can select/highlight nets, components, to make measurements, etc.without starting the "big" software Altium.
Having said that, is there any similar viewer for Orcad projects (for *.brd files)? Or can it be exported to any other format so that I can use any viewer?
 Thanks.
  • ScottCad
    ScottCad over 11 years ago
    Sure
    http://www.cadence.com/products/pcb/Pages/downloads.aspx
    Scott
  • redwire
    redwire over 11 years ago
     You are aware that Cadence has a free viewer that allows users to review boards?  http://www.cadence.com/products/pcb/Pages/downloads.aspx
    Altium can read the boards (via conversion).  Other means exist but not sure if they make sense....
  • steve
    steve over 11 years ago
     The tools will run in "demo" or lite mode without a license and work exactly the same (except you can't save or output data). If you have a licensed version then you may need to adjust the CDS_LIC_FILE so that it is not set then when you start Capture it runs in demo mode. For PCB Edtior make sure you start allegro with a -orcad (start -> run ->allegro -orcad) and without a license it will run in demo mode.
  • redwire
    Cool, thanks!!  Did not know that little gem.
  • isii
     Ok, thanks!
    It's what I was looking for, a "simple" viewer of *.brd files. So now I'll be sure of not modifying the original files when checking the design.
