  3. Importing a .DXF file (attached in this post) in Allegr...
  • Views 35246
Importing a .DXF file (attached in this post) in Allegro
RFStuff
RFStuff over 12 years ago
 Dear All,
I  am using Allegro 16.2. I want to import a .DXF file ( attached in this post).
Basically it is a package symbol layout with mechanical holes.
I am confused in setting the layer mapping.
Could anybody please go through this file and tell me what to be done to import this file so that no informations in it is missed.
Kind Regards,
SBT-QFN-4006_layout.DXF.tar.gz
  • steve
    steve over 12 years ago
     The basics are you map a dxf layer to a layer (class/subclass) in Allegro. Here's a video showing an example. http://www.youtube.com/watch?v=wTegtW9bPCs
  • VincentS
    VincentS over 12 years ago
    RF,
     I down loaded and unpacked your dxf and was able to import it tp allegro with no issues. Here is how I did it :
    1 - From the file menu select import dxf.
    2 - When the dialog box opens click the browse button and select the dxf
    3 - Select units : inches (we work in inches)
    4 - check incremental addition
    5 - click edit/view layers
    6 - select the class and sub class you want. (I selected package geometry and assembly top)
    7 - click ok, then import
    In it came.
    Here is the .cnv file that was created :
     #This is the Layer Conversion File used for
    #importing DXF data into Allegro/APD.
    #CLASS!            SUBCLASS!                 DXF_LAYER!
    PACKAGE GEOMETRY!
                       ASSEMBLY_TOP!             0!
    #END
    Hope this helps.
    Vin
  • RFStuff
     Dear Vin,
    Thnaks a lot for your reply.
    I am confused in step 6. What class and sub-class actually to be selected.
    I am expecting that this .DXF file will create the package symbiol which is going to be used in the layout.
    I did the way you did and I got something like the image attached in this post.
    But pad foot-print and the holes are NOT suitable for using in PCB layout.
    Kind Regards,
  • VincentS
    You can import to the class and sub class of your choice. If you are going to use this dxf as a model fot creating a footprint you can import it to Board Geometry Dimension. Once imported you can use it as a guide to place yout pads. Caution : make sure you follow the manufacturers dimensions. Even with the dxf you will still need to design the pad stacks.
     You might find this helpful : http://www.pcblibraries.com/Products/FPX/Allegro.asp
    I use the Mentor LP Wizard for footprint design.
  • RFStuff
     Dear Vincent,
    Thanks a lot for your reply.
    Currently I am using dimension of 1-mil grid spacing.
    How can I know the  manufacturer's dimensions from the given .DXFfile ?
    Kind Regards,
