  3. Process to generate a Pick & palce File
  • Subscribers 163
  • Views 2417
Crispy
Crispy over 12 years ago
 What is the procedure to create a Pick & place file?
  • steve
    steve over 12 years ago
     You have two options:- Tools - Reports - Component Report, or customise a New/Edit one to suit. File - Export - Placement. You can also send them an odb++ file or an ipc2581 file both are standard manufacturing output files that most Assembly houses can use).
