  3. Assign pin number to multiple parts of homogeneous package...
  • Subscribers 163
  • Views 17221
Assign pin number to multiple parts of homogeneous package in OrCAD
admin
admin over 12 years ago
Hi All, a newbie quetion here. I have got a package with 2 logic gates (6 pins) and I am working on the schematic symbol of it.
The pin 1, 2 and 5 make up one logic gate while 3, 4 and 6 make up the other.
I guess I shall create a homogeneous  package with 2 parts. The question is when I place the pins, I can only assign 3 pin numbers (1, 2 and 5) since there is only one part in the parts Editor of OrCAD.
How can I assign the 3, 4 and 6 to the other 3 pins? is it only done when the 2 parts of the package are placed in the schematic?
Thanks in advance.
  • redwire
    redwire over 12 years ago
     When you are in the parts editor and you have placed all the pins of gate 1, change the view to the next package and the gate will look identical but the pins won't be numbered.  You need to just double-click on the pins and set the number.   See if that works...
  • admin
    Hi redwire, Thanks for the explanation. Yes, just need to switch the part view will do.
  • steve
    steve over 12 years ago
     You can also use View - Package, Edit - Properties which brings all the pins up in a table view that you edit.
