  3. Do I need termination resistors for low speed RAM?
  • Views 14539
Leeya
Leeya over 12 years ago
Hi, I am doing a desing with FPGA and RAM, The RAM is running at about 200 MHZ (Not a DDR3).
Do I have to put termination resistors in this design? The PDF file doesn't say anything~~
Is there any frequency mark, that I have to put termination resistor?
  • VelmuruganM
    VelmuruganM over 12 years ago
    Hi Leeya,
    For  200MHz operation we may not need the termination resistor.
  • VincentS
    VincentS over 12 years ago
    It has been my experience that series termination is needed. A good way to determine a starting value and location is by using a simulation tool like Hyperlynx. If you do not have access to simulation tools I would put series termination footprints in the board design and install 0 ohm jumpers so the design can be evaluated on the bench. If needed you can add what ever value gives you satisfactory results without respinning the board.
  • Leeya
    I do believe they may need termination resistors~But this time, I just leave it alone, I will do a SI analysis tomorrow~~
    Thanks for reply~
