  3. refresh single occurance of refdes
  • Subscribers 166
  • Views 12695
padmaster
padmaster over 11 years ago
 I know I had read about the ability to refresh the refdes of a single part but for the life of me I cannot find it.
How do I do this?
  • redwire
    redwire over 11 years ago
     Tools->Update Symbols
    Then provide the refdes in a *.lst file
  • VincentS
    VincentS over 11 years ago
    In 16.6 set your application mode to placement edit then hover over the part you want to refresh and right click. Select symbol instance and your ref des should come back. Hope this helps.
  • VincentS
    In 16.6 set your application mode to placement edit then hover over the part you want to refresh and right click. Select refresh symbol instance and your ref des should come back. Hope this helps.
  • padmaster
     Thanks VincentS
