  3. Aspect ratio
  • Views 16552
Aspect ratio
M sakthi S
M sakthi S over 11 years ago
What is mean by aspect ratio in pcb design?
  • KARPCB
    KARPCB over 11 years ago
    Hi Sakthi,
    Aspect ratio is the ratio of board thickness to Smallest via diameter.
    Example:
    board thickness : 64mils (1.6mm)
    smallest hole : 8mils
    Aspect ratio is : 64/12 =  8:1
    The larger the aspect ratio, the more difficult it is to achieve reliable plating.
    Karthik.
  • KARPCB
    Hi Sakthi,
    Example:
    Aspect ratio is : 64/8 =  8:1
     Karthik.
  • M sakthi S
    Hi karthik,
     Got it...
     thank you...
    So, it is important one when we decide stack up.. correct?
