  3. Export Artwork Control Form?
  • Views 17954
Lock2002
Lock2002 over 11 years ago
Is it possible to export a Artwork Control Form setup? I'm trying to avoid doing it manually.
  • fxffxf
    fxffxf over 11 years ago
     File -> Export Parameters
     Select Artwork output and give it an output file name
  • Lux4al
    Lux4al over 5 years ago in reply to fxffxf
    We have a new copy of OrCAD 17.2 PCB editor and I can't find File -> Export Parameters.  I don't even see an export option in the files drop down.  Please let me know what I'm missing.
    Thanks, Al
  • steve
    steve over 5 years ago in reply to Lux4al
    Try Export - More - Color/Board Parameters or for this another method is in the artwork control form check the box for the films you want to reuse (don't usually bother with copper layers since they are automatically made) then right click on a film name and choose Save all checked. This writes a txt file out of the films. Open the new design and in the artwork control form use the Add button to browse for this txt file.
  • Lux4al
    Lux4al over 5 years ago in reply to steve
    Thanks, that was a big help.  Can a DXF map be saved?
