  3. Why can't I login to this forum with IE?
  • Subscribers 166
  • Views 2721
Roger BFS
Roger BFS over 11 years ago
Just a repetitive problem I'm having.  My Win7 64-bit PC and IE10 will not let me log-in to the Cadence forum.  No errors, block notices or anything.  It just won't do it.  Log-in attempts spend a few secs "waiting circle" and then return me to the login screen.
Chrome on the other had has no problem from the same PC (i.e. I'm here now).
 Anyone got any Microsoft clues?
  • kmastrok
    kmastrok over 11 years ago
    From my XP-32 SP3 IE8 system, everything is OK
  • rgwetzel
    rgwetzel over 11 years ago
    Hi Roger,
    I have the same problem with my Win7 64-bit and IE8. I also use Chrome for this forum.
    Bob
  • Roger BFS
    Thanks Bob.
    I started having this issue sometime last year with IE9, but after "upgrading" to 10, has gotten progressively worse. Have had to spend many hours debugging a few other sites as well.  Most problemsn have been due to some goof from the web developers using "out of date" coding, or "too new" coding for IE to cope correctly.
    I am hoping some Microsoft experts here might have some clues as to what to look at.  Microsoft just recommended uninstall/reinstall of IE - - helpful of course in causing a week of re-tweaks to my system to get everything that wasn't broken working again!
  • admin
    admin over 11 years ago
     Hi Roger,
    You can't  login from cadence.com website using IE10?
  • Roger BFS
    Yes, cadence.com is screwed up - actually none of the forums allow login from my IE10.
    I have just spent a few more more hours of debugging and posted this issue on the feedback forum as well alongt with a pdf screenshot of several debugger script error problems.  See http://www.cadence.com/Community/forums/p/29024/1332917.aspx#1332917.
    I already have all the cadence site urls in my "trusted zone" and chased every "security issue" I can think of.  Looks like its your website to me.  Think there's several html typo problems scattered around.
