  3. [DE HDL] Negative pin name with bar
  • Views 15583
vduck
vduck over 11 years ago
I want to use Part Developer to create a pin with the bar above the pin name, for example, pin PC6 (RESET) of ATmega8 with the bar above RESET. In Design Entry CIS or some other capture tools, I can do it by adding some extra character, for example R\E\S\E\T\.
What I should do?
  • oldmouldy
    oldmouldy over 11 years ago
    DE-HDL has it's own conventions for this, see page 567 pf the Part Developers User Guide, pdv.pdf in the doc\pdv directory of the product installation, "Low Asserted Pin Names should be denoted only with an asterisk (*), (for example OE*), or _N, (for example OE_N). All low asserted pins should appear as bubbles and not straight pin stubs."
