  3. Unplaced/Placed symbol;s in PCB EDITOR
  • Replies 10
  • Subscribers 163
  • Views 7266
Lennie
Lennie over 11 years ago
I have loaded an netlist in the PCB editor and since the symbols are not placed I cannot see any of the symbols. I know they are there since Place/Manual shows all the reference designators. Why can't I see the symbols ?
I then used Quickplace and all the symbols are located on the right side of the board. I want to be able to select certain reference designators to group the symbols. When I goto Manual Place there are now no reference designators. How do you select a group of reference designators ?
Is there anything that explains the differentces between unplaced and placed symbols ?
TIA Lenny
  • oldmouldy
    oldmouldy over 11 years ago
    You are looking at the canvas, "placed parts" would be on the canvas, "waiting to be placed parts£ are on the Place>Manually list - strictly speaking, in the Components by Refdes selection. You can get a report of parts in the database from Tools>Quick Reports>Component Report, this won't distinguish between "placed" and "unplaced" parts though - you can get that from Tools>Quick Reports>Unplaced Components Report. Display>Status and click the button to the left of Unplaced Symbols, or Tools>Quick Reports>Symbol Availability Check will report the current PSMPATH and any symbols not found in those settings. You get a preview of the symbol to be placed when it is selected from the Place>Manually list. If you have the schematic and board in sync and both open, you can start Place>Manually in PCB Editor and pick parts to be placed from the schematic that are on the Place>Manually list, they will be attached to the cursor when the mouse enters the PCB Editor canvas.
  • oldmouldy
    At least on reason that you don't want to this is that you design could potentially have thousands of components within it, it is definitely NOT productive to start with "all" the parts in the canvas. If you only have a small number of components, you can opt to distribute them about a Package Keepin, or user pick, using Quickplace. Quickplace also has options to Place by Room, Schematic Page, Component Class and so on, to assist with placement.
  • chads108
    chads108 over 11 years ago
    That is just the way Allegro works.  There several different ways of laying out a board.  Some prefer to have everything placed outside the board and drag it in.  I myself just wouldn't want 4000 footprints setting outside my board and have to figure out which ones to drag in.  I prefer to work off the schematic and place based on reference designator.  I can go through the list of unplaced components and select the ones I want at that time or, if Capture or Design HDL is your front-end, you can interactively select a part in the schematic and the cooresponding footprint will attach to your cursor for placement on the board (nice if you use dual screens).  Allegro gives you the option of doing it how you would prefer.
    Chad
  • Lennie
     Ok Thanks. I am learning Allegro coming from Pads and thought it was strange how this worked. Just a new way of doing things.
  • Lennie
