  3. CIS connected to MySQL database
  • Views 16170
stetag
stetag over 11 years ago
I tried to configure CIS to my Enterprise MySQL Database but Orcad return the follow error message:
ERROR(ORCIS-6233): The Table Property Type of the field PartNumber in table Resistors is not of type TEXT, STRING or CHARACTER. The Table Property Type of the field assigned as Property Type Part_Number has to be one of the above.
this is the structure of my table:
CREATE TABLE `Resistors` (
 `ID` int(10) unsigned NOT NULL,
  `PartNumber` text,
  `PArtType` varchar(255) DEFAULT NULL,
  `SchematicPart` varchar(255) DEFAULT NULL,
  `Value` varchar(255) NOT NULL,
  `Availability` varchar(255) DEFAULT NULL,
  `Data Sheet` varchar(255) DEFAULT NULL,
  `Description` varchar(255) DEFAULT NULL,
  `Manufacturer` varchar(255) DEFAULT NULL,
  `MftrNb` varchar(255) DEFAULT NULL,
  `PCBfootprint` varchar(255) DEFAULT NULL,
  PRIMARY KEY (`ID`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
Can you help me?
Best regards
Stefano
  • oldmouldy
    oldmouldy over 11 years ago
    Set the Field Type to VARCHAR(<some number>) for all the fields in the database, they will be correctly recognised as "text" - this is down to the nuances of SQL and "Microsoft Jet" data sources. You might want to restrict some of the field sizes since many of these will never be 255. You probably want to have "PartNumber" as your primary key to avoid duplicates of PartNumber and associated issues.
  • stetag
    I canged the field to varchar and set as primary key the partNumber column, but still the error
      `PartNumber` varchar(45) NOT NULL,
      `PArtType` varchar(45) DEFAULT NULL,
      `SchematicPart` varchar(45) DEFAULT NULL,
      `Value` varchar(100) DEFAULT NULL,
      `Availability` varchar(45) DEFAULT NULL,
      `Data Sheet` varchar(254) DEFAULT NULL,
      `Description` varchar(254) DEFAULT NULL,
      `Manufacturer` varchar(45) DEFAULT NULL,
      `MftrNb` varchar(45) DEFAULT NULL,
      `PCBfootprint` varchar(45) DEFAULT NULL,
      PRIMARY KEY (`PartNumber`) USING BTREE
  • oldmouldy
    I have no idea, this SQL works with MySQL to create a Resistor table for the default Bench database, specify the <database> name:
    USE <database>;
    DROP TABLE IF EXISTS Resistor;
    CREATE TABLE Resistor (
    PartNumber VARCHAR(50) NOT NULL PRIMARY KEY,
    Parttype VARCHAR(50),
    Value VARCHAR(50),
    Description VARCHAR(50),
    Power VARCHAR(50),
    Tolerance VARCHAR(50),
    SchematicPart VARCHAR(50),
    LayoutPCBFootprint VARCHAR(50),
    AllegroPCBFootprint VARCHAR(50),
    PSpice VARCHAR(50),
    ManufacturerPartNumber VARCHAR(50),
    Manufacturer VARCHAR(50),
    DistributorPartNumber VARCHAR(50),
    Distributor VARCHAR(50),
    Price DOUBLE,
    Availability VARCHAR(50),
    Datasheet VARCHAR(50),
    ActivepartsID VARCHAR(50)
    Maybe you need to "drop" the current table before creation of the replacement?
  • stetag
    **RESOLVED**
    I found my problem,
    I need to use the "MySQL ODBC x.x ANSI Driver" and not the  "MySQL ODBC x.x Unicode Driver"
    Tanks you for your help!
