  3. Set LED color with CIS Database
  • Views 13548
isii
isii over 11 years ago
 I've already finished the CIS Database for all components we use in our designs, and it works properly.
There is only one pending issue: how to set automatically the LED color depending on LEd reference we're using. I mean, when I place a exact LED reference from our database, I need that the color of the LED must bered, green, or whatever, not the default color (blue).
I see that there are many property types (cost, footprint, etc) when you import from the database, but not color. Any idea for this problem?
Thanks.
  • steve
    steve over 11 years ago
     Add a "Color" column to your database so then you can pick the correct one. Surely the part numbers would be different for the LED's with different colors so add them in as new line items to the database PN001 - Red LED, PN002 - Green LED etc.
  • redwire
    redwire over 11 years ago
     We found that adding "color" to the CIS database caused a conflict with an inherent property in OrCAD.  So what did we do?  We changed the property to "Colour" and it worked.  You can even promote the property onto the silk layer when the LED comes in.
