  3. Error with Spice Model ATF34143
  • Replies 8
  • Views 18374
zjc202
zjc202 over 11 years ago
Hi
I downloaded a Spice model from Avago Technologies http://www.avagotech.com/pages/en/rf_microwave/transistors/fet/atf-34143/ but the spice model seems to be not usable.
The error message given is:
ERROR(ORPSIM-15108): Subcircuit BATF34143 used by X_U8.XDIE is undefined
The Spice Model provided is:
*ATF-34143 packaged FET model
.SUBCKT ATF34143  16   14   15
RR2     2       1       0.1
RR9     4       3       0.1
RR5     1       5       0.1
LL2     5       SOURCE  0.1nH
LL7     SOURCE  7       0.1nH
LL6     SOURCE  8       0.1nH
RR6     8       2       0.1
RR7     7       2       0.1
RR8     DRAIN   9       0.1
LL5     9       11      0.1nH
LL8     2       15      0.05nH
LL10    15      1       0.1nH
LL1     14      4       0.8nH
LL9     11      16      0.6nH
CC3     11      2       0.15e-12
CC4     1       4       0.15e-12
LL4     3       GATE    0.1nH
*CALL DIE MODEL
XDIE    DRAIN   GATE    SOURCE  BATF34143
.ENDS
****     GaAs MESFET MODEL PARAMETERS
.SUBCKT ATF34   D       G       S
.MODEL BATF34143 GASFET ( LEVEL=2, Vto=-0.95, Beta=0.24, Lambda=0.09, Alpha=4,
                    +   B=0.8, Tnom=27, Vbi=0.7, Delta=0.2, Cgs=0.8 pF,
                    +   Cgd=0.16 pF, Rd=0.25, Rg=1, Rs=0.125, Cds=0.04 pF,
                    +  Is=1 nA, P=0.65)
                    .ENDS
**ATF-34 FET chip Statz model parameters for small signal operation.
*STATZ FET MODEL
*                    IDS model       Gate model      Parasitics      Breakdown       Noise
*                    NFET=yes        Delta1=0.2      Rg=1            Gsfwd=1         Fnc=1E6
*                    PFET=no         Gscap=3         Rd=0.25         Gsrev=0         R=0.17
*                    Idsmod=3        Cgs=0.8 pF      Rs=0.125        Gdfwd=1         C=0.2
*                    Vto=-0.95       Gdcap=3         Lg=.0075 nH     Gdrev=0         P=0.65
*                    Beta=0.24       Cgd=0.16 pF     Ld=.0075 nH     Vjr=1
*                    LAMBDA=0.09     Cds=0.04 pF     Ls=.0025 nH
*                    Alpha=4         Crf=0.1         Is=1 nA
*                    B=0.8           Rc=125          Ir=1 nA
*                    Tnom=27                         Imax=0.1
*                    Vbi=0.7
Is there anything wrong with the Spice model?
Many Thanks
Jun
  • oldmouldy
    oldmouldy over 11 years ago
    I would say that there is, XDIE calls a subcircuit BATF34143 but that is defined as a model, the subcircuit name that references it is actually ATF34 so the correct subcircuit call would be:
    XDIE DRAIN GATE SOURCE ATF34
    See if that change will get the model to work.
  • zjc202
     Hi
    Thanks for your prompt reply but it doesn't work
    Regards
    Jun
  • oldmouldy
    If the text provided accurately reflects the modle text, the ".ENDS" statement for the ATF34 subcircuit is not at the beginning of the line. That could be an issue. Also provide some information of what message you get when running the simulation after the changes.
  • zjc202
     Hi
     It still shows the same error  message
    ERROR(ORPSIM-15113): Model BATF34143 used by X_TB_U1.B1 is undefined
  • oldmouldy
    It's certainly a similar message, select the Project Manager window, and then the DSN file and use File>Archive Project to create a single file of the project and attch that to the forum so that all the data for the project can be examined to determine what the problem is.
