  3. Expecting keyword STIMULUS or device X_F1.V1 is undefined...
  • Subscribers 163
  • Views 6150
Expecting keyword STIMULUS or device X_F1.V1 is undefined - OrCAD 16.5
jlgm
jlgm over 11 years ago
 Hello
I have a problem. I can't simulate a circuit because the models are missing. I am new to OrCAD (all versions) so I was creating a schematic of a buck converter. I should be able to simulate but I can't.
Please let me know exactly how to resolve it. Here are the netlist & the errors. Thank you very much
Hello
**** 05/29/14 19:53:47 ****** PSpice 16.5.0 (April 2011) ****** ID# 0 ********
 ** Profile: "SCHEMATIC1-Converters"  [ C:\SIMULATIONS\CONVERTERS\CCCS AVERAGEDBUCK
 ****     CIRCUIT DESCRIPTION
** Creating circuit file "Converters.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Cadence\SPB_16.5\tools\PSpice\PSpice.ini file:
.lib "nom.lib"
*Analysis directives:
.TRAN  0 40ms 0 0.0001
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source CONVERTERS
C_C1         N26126 0  50u  TC=0,0
E_E1         IL1 0 POLY(2) N44888 0 N44888 0 0.0 0.0 0.0 0.0 1.0
L_L1         IL1 N26126  25uH
X_F1    N41090 IL1 N26140 IL1 SCHEMATIC1_F1
V_V8         N26140 0 10Vdc
V_V1         N44888 0 0.5V
R_R3         0 IR3  1 TC=0,0
V_V2         IR3 N44888 DC 0Vdc AC 1Vac
R_R4         IL1 N41090  1n TC=0,0
R_R1         N26126 0  1 TC=0,0
.subckt SCHEMATIC1_F1 1 2 3 4
F_F1         3 4 POLY(2) V1 VF_F1 0.0 2.0 1.0
VF_F1         N44888 0 1 2  DC 0V AC 0V
.ends SCHEMATIC1_F1
**** RESUMING Converters.cir ****
.END
**** EXPANSION OF SUBCIRCUIT X_F1 ****
X_F1.F_F1 N26140 IL1 POLY 2 X_F1.V1 X_F1.VF_F1 0.0 2.0 1.0
X_F1.VF_F1 X_F1.N44888 0 1 2
ERROR -- Expecting keyword STIMULUS, saw 2.
or
**** 05/29/14 20:16:19 ****** PSpice 16.5.0 (April 2011) ****** ID# 0 ********
*Libraries:
* Local Libraries :
.lib "nom.lib"
* source CONVERTERS
V_V8         N26140 0 10Vdc
V_V1         N44888 0 0.5V
R_R3         0 IR3  1 TC=0,0
VF_F1         1 2  DC 0V AC 0V
.ends SCHEMATIC1_F1
.END
ERROR(ORPSIM-15090):  device X_F1.V1 is undefined
  • oldmouldy
    oldmouldy over 11 years ago
    1st sample: VF_F1 has too many nodes for an independent voltage source, should be V<name> +node -node then the DC / AC parameters. (For a DC, or AC, declaration, PSpice will know that you mean "volts DC", or "volts AC", there is no requirement to specify Vdc, or Vac, in the value)
    2nd sample, this subcircuit:
    .ends SCHEMATIC1_F1
    is trying to reference node V1 as a controlling input for the "POLY", but there is no node of that name in the subcircuit.
