  3. Issue with FPOLY (CCCS) in order to use poly(n), where n...
  • Views 1567
Issue with FPOLY (CCCS) in order to use poly(n), where n>1
jlgm
jlgm over 11 years ago
 Hello
I have a new problem with "Current'Controlled Current Source" CCCS with POLY(n), where n>1.
I can't obtain a current output different to zero caused by entry second, i.e.,
VOLTAGE SOURCE CURRENTS
    NAME         CURRENT
    X_F1.V_VDT   0.000E+00      <----this value must be different to zero, because variable Duty=03
Please let me know exactly how to resolve it. Here are the netlist & the errors.
Thank you very much
**** 06/02/14 12:48:43 ****** PSpice Lite (October 2012) ****** ID# 10813 ****
 ** Profile: "SCHEMATIC1-Converters"  [ C:\CCCS AveragedBuck\converters-pspicefiles\schematic1\converters.sim ]
 ****     CIRCUIT DESCRIPTION
** Creating circuit file "Converters.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Documents and Settings\Administrador\Datos de programa\SPB_16.6\cdssetup\OrCAD_PSpice/16.6.0/P
.lib "nomd.lib"
*Analysis directives:
.TRAN  0 40ms 0 0.0001
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source CONVERTERS
C_C1         N26126 0  50u  TC=0,0
E_E1         N26376 0 POLY(2) N26140 0 N821065 0 0.0 0.0 0.0 0.0 1.0
L_L1         N47845 N26126  25uH
V_E         N26140 0 10Vdc
X_F1    N26376 N47845 N26140 N26376 SCHEMATIC1_F1
R_R1         N26126 0  1 TC=0,0
R_R26         N821065 0  1
V_VDT         N821065 0 {Duty}
.PARAM  duty=0.3
.subckt SCHEMATIC1_F1 1 2 3 4
F_F1         3 4 POLY(3) V_F1 V_VDT V_F1 0.0 0.0 1.0 0.0 0.0 0.0 0.0 0.0 0.0
+  0.0 0.0 0.0 0.0 0.0 0.0
V_F1         1 2
V_VDT         N821065 0
.ends SCHEMATIC1_F1
**** RESUMING Converters.cir ****
.END
 ****     INITIAL TRANSIENT SOLUTION       TEMPERATURE =   27.000 DEG C
 NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE     NODE   VOLTAGE
(N26126)    3.0000 (N26140)   10.0000 (N26376)    3.0000 (N47845)    3.0000
(N821065)     .3000                   (X_F1.N821065)    0.0000
    NAME         CURRENT
    V_E         -7.000E-12
    V_VDT       -3.000E-01
    X_F1.V_F1    3.000E+00
    TOTAL POWER DISSIPATION   9.00E-02  WATTS
          JOB CONCLUDED
 ****     JOB STATISTICS SUMMARY
  Total job time (using Solver 1)   =         .05
  • oldmouldy
    oldmouldy over 11 years ago
    I am not too sure what you are trying to achive with this model but a POLY(3) is a fairly complex way to handle this since the coefficients can rapidly get out of hand, unless you need to control "all" the coefficients, "regular" ABM expressions might be a better approach. In any case, for this:
    V_F1         1 2
    V_VDT         N821065 0
    .ends SCHEMATIC1_F1
    The V_F1 is repeated so this is only a POLY(2) (?). The only coefficient is for 1.0*(V_VDT), V_CDT references node N821065 which is not part of the subcircuit, see  (X_F1.N821065)    0.0000 in the output file and hence the output.
    I would have expected more nodes for the subcircuit, something like:
    .subckt <name> 1 2 3 4 5 6 7 8
    F_F1 7 8 POLY(3) VF1 VF2 VF3 <coefficients>
    VF1 1 2 0
    VF2 3 4 0
    VF3 4 5 0
    .ends
     See the section in the pspcref.pdf, doc\pspcref directory of the installation, page 172 onwards.
  • jlgm
     Hi
    I have the problem when entering data in tab SCHEMATI..* [Property Editor] of the CCCS source
    I enter the data as follows
    COEFF             0.0 1.0 1.0 1.0
    PSpice Template   F^@REFDES %3 %4 POLY(3) V_F1^@REFDES V_VF2^@REFDES V_VF3^@REFDES \n+ @COEFF \nV_F1^@REFDES %1 %2 0V \nV_VF2^@REFDES N821065 0 0V \nV_VF3^@REFDES N822098 0 0V
    but I can't obtain a current output different to zero caused by second and third entry, i.e.,
        NAME         CURRENT
        X_F1.V_VF2   0.000E+00      <----this value must be different to zero, because V_VF2  N821065 0 0.5
        X_F1.V_VF3   0.000E+00      <----this value must be different to zero, because V_VF3  N822098 0 0.8
    Since COEFF are 0.0 1.0 1.0 1.0 then the results should be as follows
        NAME         CURRENT
        X_F1.V_VF2   0.500         <----because R_R26  N821065 0  1 and V_VF2  N821065 0 0.5
        X_F1.V_VF3   0.800         <----because R_R27  N821065 0  1 and V_VF3  N822098 0 0.8
    Therefore, the final value of the dependent current source CCCS should be 6.300A
    I cannot increase the number of nodes in the subcircuit
    VF1 1 2 0
    VF2 3 4 0
    VF3 4 5 0
    .ends
    Regarding pspcref.pdf file, where they are located currentsense and voltagesense, ammeter and voltmeter, respectively. They can be used in CCCS.
    Please show me a procedure in order to know exactly how to resolve it. Here are the netlist.
    Thank you very much
    **** 06/04/14 00:21:10 ****** PSpice Lite (October 2012) ****** ID# 10813 ****
    *Libraries:
    * Local Libraries :
    .lib "nomd.lib"
    .OPTIONS ADVCONV
    * source CONVERTERS
    V_E         N26140 0 10Vdc
    R_R26         N821065 0  1
    V_VF2         N821065 0 0.5
    R_R27         N822098 0  1
    V_VF3         N822098 0 0.8
    F_F1         3 4 POLY(3) V_F1_F1 V_VF2_F1 V_VF3_F1
    + 0.0 1.0 1.0 1.0
    V_F1_F1         1 2 0V
    V_VF2_F1         N821065 0 0V
    V_VF3_F1         N822098 0 0V
    .ends SCHEMATIC1_F1
    .END
    (N26126)    5.0000 (N26140)   10.0000 (N26376)    5.0000 (N47845)    5.0000
    (N821065)     .5000                   (N822098)     .8000
    (X_F1.N821065)    0.0000              (X_F1.N822098)    0.0000
        NAME         CURRENT
        V_E         -5.000E+00
        V_VF2       -5.000E-01
        V_VF3       -8.000E-01
        X_F1.V_F1_F1   5.000E+00
        X_F1.V_VF2_F1   0.000E+00
        X_F1.V_VF3_F1   0.000E+00
        TOTAL POWER DISSIPATION   5.09E+01  WATTS
              JOB CONCLUDED
      Total job time (using Solver 1)   =         .02
  • jlgm
    Hi
    I have the problem when entering data in tab SCHEMATI.., i.e., [Property Editor] of the CCCS source
        NAME         CURRENT
        NAME         CURRENT
    Therefore, the final value of the dependent current source CCCS should be 6.300A in Schematic circuit
    In other words, I cannot increase the number of nodes in the subcircuit and I cannot modify entered nodes to FPOLY, like this
    VF1 1 2 0
    VF2 3 4 0
    VF3 4 5 0
    .ends
    With respect pspcref.pdf file, I find an ammeter and voltmeter, currentsense and voltagesense, respectively.
    How I could be using this elements? Is it possible that these can be used with CCCS source.
    Please show me a procedure in order to know how to resolve it. Here are the netlist.
    Thank you very much
    *Libraries:
    * Local Libraries :
    .lib "nomd.lib"
    .OPTIONS ADVCONV
    * source CONVERTERS
    V_E         N26140 0 10Vdc
    R_R26         N821065 0  1
    V_VF2         N821065 0 0.5
    R_R27         N822098 0  1
    V_VF3         N822098 0 0.8
    + 0.0 1.0 1.0 1.0
    V_F1_F1         1 2 0V
    .ends SCHEMATIC1_F1
    .END
        NAME         CURRENT
        V_E         -5.000E+00
        V_VF2       -5.000E-01
        V_VF3       -8.000E-01
              JOB CONCLUDED
