  3. (SPMHGE-30): Refdes was not found.
  • Subscribers 162
  • Views 14760
Lennie
Lennie over 12 years ago
 I get the following error (SPMHGE-30): Refdes was not found. when trying to assign a reference designators using Logic/Assign Refdes and select a symbol that is J? for its refdes. What am I doing incorrectly ? Where isa this error defined ?
  • oldmouldy
    oldmouldy over 12 years ago
    Yes, that's exactly it. For example, you can have a "master board" with preplaced components and then assign the "actual" references from the netlist when it is loaded.
  • oldmouldy
