  3. How to edit the stackup design for the single layer board...
  • Subscribers 163
  • Views 14336
How to edit the stackup design for the single layer board?
Dhamodharann
Dhamodharann over 11 years ago
Hi...
I had worked two to four layers, currently the single layer pcb board is been preferred by customer. so i want to create an single layer board stackup means, how can i enable he single layer mode in the X section.
Whenever i am tying to get enable the single layer means it's not get enabling on the X section option.So anyone provide me an solution for this.
Thanks & Regards
Dhamodharann
  • oldmouldy
    oldmouldy over 11 years ago
    You will need a two layer board, then disable Etch Allowed on the Top, or Bottom layer in the Physical Constraint Sets, any existing etch will DRC on the "not allowed" layer so that you can identify and remove it.
  • Dhamodharann
    Thanks Oldmouldy. The option you specified was been get working.Now i am able to do the single layer board. Thanks & Regards Dhamodharan
