  3. How to edit the DFA bound top & Place Bound top outlines...
  • Subscribers 163
  • Views 2810
How to edit the DFA bound top & Place Bound top outlines ?
Dhamodharann
Dhamodharann over 11 years ago
Hi.. I had created the smd footprint with the DFA bound top & Place bound top outlines. Some mistake done in the outline drawing, the dimension want to be extended. So how can i edit the the outlines.. Thanks & Regards Dhamodharan
  • steve
    steve over 11 years ago
     Shape - Select Shape or Void then left click the shape, you'll see boxes in teh corners so you can drag corners or edges to extend. You can also use Shape - Edit Boundary. There are videos on youtube Channel Parsyseda showing you this. Search for Shapes...
