  3. Physical Viewer - Show pin number?
  • Views 3115
henryy
henryy over 11 years ago
I want to show all the pin numbers in the physical viewer, not just use the show element command and move the mouse over a specific pin to show. How do I set it up?
  • steve
    steve over 11 years ago
     Display - Color Visibility then turn on Package Geometry / Pin Number as the layer. You also need to ensure that the Top / Pin layer is also turned on for top side components and Bottom / Pin layer is on for the bottom side.
  • henryy
    Thanks.
