  3. Drawing the silkscreen oulines the width of the shape can...
  • Subscribers 162
  • Views 16039
Drawing the silkscreen oulines the width of the shape can be increased?
Dhamodharann
Dhamodharann over 12 years ago
Hi.
I had created the footprint and then i had tried  to put the shape outline for that, i want to increase the shape outline width it is possible from 0.127mm to 0.254mm. Is there any option to increase the width of it.
Thanks & Regards.
Dhamodharan
  • oldmouldy
    oldmouldy over 12 years ago
    Edit>Change, In Options, Check the box for Line Width and Set the new value for the width, in the Find filter, check that Lines are enabled, select the item, or items, in the design, or symbol editor, the width will change, right-click>Done to accept the change.
  • Dhamodharann
    thank you old mouldy.. The solution is getting work for me.
