  3. Function keys are not get working in the board file?
  • Subscribers 163
  • Views 13816
Dhamodharann
Dhamodharann over 11 years ago
Hi.. I had edited the env variable file with the note pad. Then i had assigned some keys for shortcut commands. In that, funckey i "zoom in" is get not working. The zoom out key is get working.What is the problem in the env editing file.Any solution for the problem??? Thanks & Regards Dhamodharan
  • steve
    steve over 11 years ago
     for function key definition doesn't need the quotes so you just need funckey i zoom in.
  • steve
