  3. Allegro Design Entry CIS - "Select entire net does not work...
  • Views 2412
Allegro Design Entry CIS - "Select entire net does not work on separate pages"
phandinh1508
phandinh1508 over 11 years ago
Hi all,
I don't know what happened  or i did somethings wrong on my schematic.
I previously could select a net that was connected by off-page in 2 pages in 1 schematic by "select entire net" then the net was hilighted (both in 2 pages).
In what way or somehow, now when i do the same excute above, the net just hilighted in one page only.
I also tried to reboot laptop but nothing better.
This makes me really confused. please help me out if you guys knowledge on this.
TDP.
  • Dhamodharann
    Dhamodharann over 11 years ago
    check the connections which you have completely done. Incase it does int work means try to repair option for capture.
  • phandinh1508
    Hi Dhamodharann ,
    Netlist has been sent to layout without errors. Could you make your suggestion "repair option for capture" clearer ?
    TDP
  • Dhamodharann
    Hi.. In case if you are using the page off connector means the nets will linked with that connection.But when you select to high light the net in one page that page entire net will be selected. In case other page nets will not be enabled, because the page off connector shows the current page what you have seeing. An ( Example:) 5V, Ground are been used in the page 1 and connected to page 2 with the off page connector means, if you open the page 1----> highlight net means, that viewing page nets will be enabled.Page 2 nets will not be highlighted. Thanks & Regads Dhamodharan
  • phandinh1508
    Hi Dhamodharann,
    If so, how to highlight a net that connects in many pages ?
    Thank you,
    TDP
