  3. Board Outline compose error
  • Replies 13
  • Views 18978
Hossein1357
Hossein1357 over 11 years ago
I am designing a new baod Allegro 16.6. When I try to compose the Outline subclass of Borad Outline I see below message without any effect on board corners. I can't compose Route Keepin nor Package Keepi.
W- (SPMHIS-473): 1 selected items completely overlapped with segments from other selected items and have been filtered.
I would really appreciate any help on this issue,
Hossein
  • steve
    steve over 11 years ago
     The warning mesaage is very accurate. You have an overlapping object of the items you are trying to compose a shape from. Maybe you have two copies of the same items on top of each other. Try the Move command and move the segments away to see if you have duplciates. Then delete the duplicates.
  • Hossein1357
    If it was the case I could move it by move utility!.. When I try to move my shape - Board outline or Route Keepin - I don't see any extra object behind it? The shape of my board is as you see below, is there anything wrong with this shape? I want to flatten corners using compose shape utility:
    board shape
    thanks,
    Hossein
  • steve
     No picture is uploaded. Can you attach your board file so we can take a closer look ?
  • Hossein1357
     I attached it.
    SSPA_V03_4.zip
  • steve
     Your board outline is already a composed closed shape, what are you exactly trying to do ?
