  3. What the drill size to be use in BB vias?
  • Subscribers 162
  • Views 14626
Dhamodharann
Dhamodharann over 12 years ago
Hi..
I am trying to work on the six layer PCB board. In that i had configured BB via for the layers what ever to be used in the board. But my doubt is for through hole via i had specified the drill and pad. For the BB via configuration whether we can use the same through hole via size or to provide the new drill and new pad size for the BB via configuration.
BB via definition is pad size should be smaller or larger than through via size. Any idea about the configuration???
Regards
Dhamodharan
  • kabalee
    kabalee over 12 years ago
    Hi dhamodharan, for blind and buried via you need to define the drill size is 6mil or less then 6 mil.please share your BGA part no i will try to help u. please read this below it will be help for u http://www.cadence.com/community/forums/T/29683.aspx
  • Dhamodharann
    Thanks kabalee. the link you provided is been get useful for me. Just now i had started to work on the 6 layer board. In that design i had tried to insert he BB vias. Thanks & Regards Dhamodharan
