  3. how to define the units in mm?
  • Subscribers 163
  • Views 16692
Dhamodharann
Dhamodharann over 11 years ago
Hi.. Just now i had start to Analyze the quality of the signals in the pcb board. In case manually i want to analyse the signal manually means how can i define the units mm? For the signal explorer the defaults unit of mils get used. Still how to change the units in mm?
  • oldmouldy
    oldmouldy over 11 years ago
    Set the following Environment Variable in the "user section" at the top of the pcbenv\env file
    set SIGXP_ALTERNATE_UNITS "<units> <accuracy>"
    <units> must be one of:
    mils
    inches
    centimeters
    millimeters
    microns
    meters
    <accuracy> can be 0 to 5
    for example:
    set SIGXP_ALTERNATE_UNITS "millimeters 2"
    will use units of mm and accuracy of 2 decimal places.
  • Dhamodharann
    Thank you steve for your reply. Still i am beginner to the sigrity, is there any tutorial for the sigrity analysis for the basic learning with some tutorials are provided.
