  3. Importing netlist removes all BGA vias
  • Subscribers 163
  • Views 15041
DonlAZ
DonlAZ over 11 years ago
We're way behind on updates and a recent one was finally installed. Now when I import Logic it removes all the vias under my BGA.
I tried fixing the part and vias but I get this error if I don't check the Ignoge Fixed property. The part nor the schematic symbol hasn't changed from when I initially laid out the board months ago.
So it either tears up  all my vias or won't come in.
#1   ERROR(SPMHNI-175): Netrev error detected.
ERROR(SPMHDB-195): Error processing 'U31': Cannot modify element; the object or a parent has the FIXED property. [help].
  • chads108
    chads108 over 11 years ago
    I ran into the same issue.  I found that if I "unmark" the fanout, the fanout will not get ripped up during import.
    Chad
  • DonlAZ
    Thanks Chad, that was it,,, I apreaciate the help!!!!!
  • chads108
    Route => Convert Fanout. Unmark will disaccosiate the fanout from the pins.  Mark will reverse the process.  The Find tab has some options for selecting what gets picked.
    Chad
